ST32L476RG dfu bootloader bug via USB?
roland van straten
Posted on September 23, 2017 at 15:43
I have a
firmware.dfu
and
firmware.hex
file generated for the
STM32L476RG
. When I use
dfu-util
and upload the file the system doesn't work, if I use my segger jtag interface and uses
SWD
to upload the firmware.hex file everything works as expected. I noticed that some of the code seems to work when using dfu-util, however it looks like a flash sector or so is missing or corrupted.
If it is a problem, is there an
errata
sheet or something about it?
Roland
#l476 #dfu
Posted on September 24, 2017 at 04:37
Pretty sure ST isn't the developer for dfu-util
https://community.st.com/0D50X00009XkeovSAB
https://community.st.com/0D50X00009XkdwKSAR
