Serial Audio Interface on STM32F429
liz
Posted on May 09, 2013 at 19:50
Can any one tell me if the SAI on F429 is able to handle multi-channel duplex TDM audio? I am hoping to get 8 in 8 out simultaneously, only using the SAI.
Also what is the 10K price of F429? I am also considering $6 C6742 from TI.
Will there be a discovery kit for the F429? When will it be available?
#under-nda #audio #stm32f429 #sai
liz
Posted on May 15, 2013 at 01:12
Please at least tell me where I can find more info about the SAI.
Posted on May 15, 2013 at 04:31
This is a user forum. You will need to get sales and technical details via classical means, call your ST rep or FAE, and sign an NDA.
jiaqi zhao
Posted on May 18, 2017 at 10:53
I have  a project that i need to make a 7 microphone array. I want to use SAI  with TDM, but I can't find any exemple. Did you solve your problem? Can you give me some suggestions?
