Nucleo-H563ZI as USB host for barcode scanner?
suriya
Split from https://community.st.com/t5/stm32-mcus-boards-and-hardware/nucleo-h563zi-as-usb-host/td-p/646056
I am New here.
I was trying to connect the USB Barcode scanner to this Nucleo Board. Did you guys find any solution to make the board act as a USB Host.
FBL
Hi @suriya
Similar issue is raised here Solved: USB_HID_Barcode Scanner - STMicroelectronics Community
Best regards,
FBL
FBL
Hi @suriya
Best regards,
FBL
