How to make a STM32 (blue pill) talk to my computer via USB (serial)?
CZeum
Hi all,
after working with Arduinos for some time now, I am currently trying to get stuff to work using a blue pill (stm32f1). I've managed to get some code working that turnes on the builit-in LED when a button is pressed using the Arduino IDE.
With that milestone achieved, I am now trying to get the STM32 to communicate with my 64bit win7 PC via serial / USB. When I plug in the STM, no connection is established. The win device manager shows an "unknown device" and under details error code 43 is given.
I've searched the net for quite some time now but haven't found a solution to my problem. I've tried a couple of drivers from this website, but noting worked. I added a 1.8kOhm resistor between PA12 and 3V3 to compensate for the wrong resistor on most blue pills (10kOhm insted of 1.5kOhm)
Maybe some of you can point me into the right direction. Should the blue pill connect automatically for serial communication via USB like other µ-controller / USB devices? If no: What do I have to do to make it work? Which driver?
Many thanks for every piece of advice!
Claus
Peter BENSCH
This thread relates to a so-called Blue Pill, which uses illegally cloned STM32F103. ST resources are only dedicated to supporting genuine ST products. We are not committed to ensuring that clones/fakes products work properly with the firmware we provide.
We recommend to purchase genuine products from STMicroelectronics and purchase them from known and trusted distributors.
This thread will now be locked. However, if you face difficulties while using genuine ST products, we’re here to assist you. Please feel free to start a new thread, and our team, along with community members, will be ready to help you with any issues/questions you encounter.
Thank you for your understanding.
/Peter
Peter BENSCH
/Peter
