How do I send data from my external sensor to Lorawan server using B-L072Z-LRWAN1 end_node example
Marshall08
Hello everyone,
I am doing project that is based on a B-L072Z-LRWAN1 core that has a couple of sensors connected to it. One of them is an ADC sensor that measures the humidity of the ground.
My problem is that I would like to send the data from an external sensor via LoRaWAN to TTN. In support they helped me with the existing example (I-CUBE-LRWAN) and told me that I could modify this code to do it.
The example project don't have an .ioc file.
what are the possible solutions to do this
Best regards, and thanks a million.
0 REPLIES 0
