FreeRTOS equivalent of uint32_t HAL_GetTick(void)
Posted on July 10, 2014 at 07:33
I'm using STM32Cube_FW_F4_V1.1.0 libraries for STM32F4. I found uint32_t HAL_GetTick(void) will provide tics in milliseconds.
I have found the following in a FreeRTOS based code .timeNowMs
xTaskGetTickCount
portTICK_RATE_MS
This problem is described athttp://forums.openpilot.org/topic/44037-gps-nmea-ubx-code-adaptaion-data-tests/?p=353138
( sorry for redirecting you). can I use it like timeNowMs = HAL_GetTick();Would this result in same functionality ? #freertos #milliseconds
