Aishwarya
Data Corruption with USB CDC communication
  • November 7, 2020
  • 840 views
Continuous transmission of data of tx rate 500 samples per seconds(33 bytes per sample) using USB virtual com port(USB CDC).
USB mode - full speed
Transmit data to serial monitor using function CDC_Transmit_FS();
Received data on serial monitor is corrupted data, and this data corruption is not regular.
To solve this problem -
  • check the status of CDC_Transmit_FS() who check the state of variable(hcdc->TxState )
  • send data after multiples of 1millisecond window.
  • Set/reset flag continuous in CDC_TransmitCplt_FS() function.
James Murray
Aishwarya
AishwaryaAuthor
hi @James Murray​
Problem is, data get corrupted when high speed data(16500 Bytes per second) transmission takes place.
