nucleo pd output 24V@3A
Joe Stavitsky
Can I safely get that power out of any of the nucleo PD boards with a usb3 pd input? Can I get any higher current or voltage?
Output is 2 pin barrel connector. Target application is fully documented here.
Thanks so much in advance
Joe
AScha.3
Supply for a soldering iron ?
Why not simply use a SMPS , you need it anyway (or , in your case, the power is coming from..? )
like this:
A variety of reasons.
I want to use standard "consumer" usb3 battery packs as supplies, the kind generally used for smartphones. Furthermore, I want to learn Nucleo.
