2013-07-09 1:51 AM
I have a question about your M24LR products. I know the product has been designed as a passive tag, For RFID communication the power come from the reader and when we want to communicate via I2C we have to power the tag via 2 power pins (VCC and VSS). My question is : if I power the tag myself (via VCC and VSS) and then try to communicate via RFID. Is it going to change the read range or not ? What energy source's the tag is going to use ? I didn't see anything about that in the data-sheet. Do you have any idea if the range will be improved ? Thank you #read-range #m24lr-range-improve-power-tag #range-antenna-m24lrSolved! Go to Solution.
2013-07-17 1:43 AM
2013-07-17 1:43 AM
