ST25R reader for MB89R118C tag
WGorm.1
Which ST25R reader would you recommend for the MB89R118C Fujitsu Tag which has FRAM of 256 memory blocks/ 2048 bytes and uses ISO/IEC15693? For some reasons I could not write or read from this NFC type 5 tag with the NFC Tap app? Please advise.
Brian TIDAL
MB89R118C is a 8-byte per block device. This can be read by any of the ST25R device (ST25R95, ST25R3911B or ST25R3916/3916B).
In ISO/IEC15693 mode, NFC Tap app is limited to 4-byte per block device thus MB89R118C cannot be read by this app.
Rgds
BT
Brian TIDAL
Rgds
BT
WGorm.1
Thank you so much! Would you recommend another app that may do 8-byte per block if any?
Brian TIDAL
Well, difficult for me to recommend an app from the competition ;) but if you google "app NFC Tag Info", you should find some apps.
Rgds
BT
