M24LR16E-R Dual EEPROM information
jguimaraes
Posted on January 23, 2014 at 16:29
I wish to know please if using this memory is there any way to access, via RF, the information that I stored via I2C. Or is the information separated, via I2C (2048 bytes) and via RF (512 blocks of 32 bits) , with no possible interaction between them?
In alternative, to access the entire memory information, by using one or the other interface, should I use instead the M24SR16-Y version?
Thank you very much.
#i2c-access #m24lr16e-r-dual-eeprom #m24lr16e
Anais GALLIGANI
Senior II
Posted on January 23, 2014 at 17:06
Hi ,
I want to know if this AN can help you
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00247968.pdf
The EEPROM memory is shared between i2C & RF. Only difference is it is addressed.
For example, bytes at the address
0000 0001 0002 0003
  in i2C are the same than 4 bytes at the RF block 0000.
Have a nice day,
ST NFC/RFID Dynamic tag support
Anais GALLIGANI
Senior II
Hi ,
0000 0001 0002 0003
Have a nice day,
jguimaraes
Posted on January 28, 2014 at 11:42
Thank you very much for the information. I'll check the AN.
Best regards
