2023-01-05 2:40 PM
Is there a list someplace of pre-certified NFC modules which use ST25 chips?
Thanks,
Scott
2023-01-16 12:30 AM
Hi Scott,
Unfortunately, such a list is currently not available.
Regarding the ST25R95/CR95HF, the X-NUCLEO-NFC03A1 board based on this device is FCC certified (https://fccid.io/YCPNFC03A1/). The ST25R95/CR95HF is not NFC Forum certified
I recommend reaching out to the local sales team, which can help you to find the right solution based on your requirements.
Rgds
BT
2023-01-06 12:50 AM
Do you refer to NFC certification? If yes, you will find a list of NFC certified devices https://nfc-forum.org/products/certified-products/
Rgds
BT
2023-01-06 7:58 AM
I'm referring to modules, not the ICs themselves, which have NFC and FCC certification. I wasn't aware of that list, so I appreciate knowing about it, but it doesn't give the IC on which each module is based. Does ST have a list of customers who have used the ST25 family in their certified end products? For instance, Nordic Semi has a list of third-party modules for each of their ICs, and it's really helpful. it would be great if ST had the same info.
As I look through the list on the NFC Forum, it appears that the ST25R95 is not listed, but other ST ICs are listed. Is the ST25R95 not certified?
Thanks,
Scott
2023-01-16 12:30 AM
Hi Scott,
Rgds
BT
2023-01-16 8:14 AM
Hi Brian,
Thank you for the confirmation. We'll sort out next steps.
Best regards,
Scott
