Is it possible to use the ST25DV_Discovery_Mboard portion of the ST25DV-Discovery kit as a standalone nucleo board without losing its original functionality?
KObir.1
We just concluded a project using the ST25DV-DISCOVERY kit and the ST25R3916-DISCO kit
The question is is it possible to use the portions of these boards as independent standalone version for each board, e.g the ST25_Discovery as a standalone nucleo board without losing the origional firmware functionality?
Brian TIDAL
Hi
not sure to fully understand your use case. Anyway, if you flash your own firmware on the mother boards (MCU part), you can later on restore the original firmware (available on st.com)
Rgds
BT
Brian TIDAL
Hi
Rgds
BT
