Is CR95HF compatible with M24LR ?
kevseryildirim01
Posted on September 22, 2016 at 12:17
Can nfc03a1 read/write the tag m24lr. In the datasheet of CR95Hf; it says that ISO15693 tags are supproted and forum tag types 1,2,3,4 as well. M24LR belongs to Forum tag type V and it supports ISO15693. So I could not make sure that can I use CR95hf as transciever for m24lr tag.
Thanks in advance.
Kawthar
Posted on September 26, 2016 at 13:51
Hello Kawthar,
Yes CR95HF support the M24LR family
Please check  AN3375 on :
http://www.st.com/resource/en/application_note/dm00025202.pdf
In addition of the NFC03 board, there are some development kit call M24LR-DISCOVERY that provide boards with CR95HF and M24LR. You will find information
http://www.st.com/content/st_com/en/products/nfc/st25-nfc-rfid-tags-readers/dynamic-nfc-tags/m24lr-series-dynamic-nfc-tags/m24lr64e-r.html
on chapter Tools and Software, folder EVALUATION TOOLS
Hello Kawthar,
