Is the ST25DV64K tag compatible with a ISO14443-A reader?
GErma.1
Hi
I would like to know if the ST25DV64K tag is going operate with a regular SO14443-A reader? I have already tested the tag against a Samsung S10 phone running the ST's app and is working perfectly.
Best Regards
Gilberto
Berenice BENVEGUDA
​Hello Gilberto,
If you need and I2C interface and ISO144443-A product you have the M24SR64K product available at the link below :
https://www.st.com/content/st_com/en/products/nfc/st25-nfc-rfid-tags-readers/st25-dynamic-nfc-tags/m24sr-series-dynamic-nfc-tags/m24sr64-y.html
the Datasheet is available here :
https://www.st.com/resource/en/datasheet/m24sr64-y.pdf
Best Regards,
BB
4 REPLIES 4
Berenice BENVEGUDA
​Hello Gilberto,
The ST25DV64K tag is going to operate well with a regular ISO14443-A reader, with respect to initialization phase ( Anticollision, RATS, Select Application, Select File commands …)
Best Regards,
BB
Berenice BENVEGUDA
Hello Gilberto,
sorry I read too fast your question
ST25DV64K is not compatible with an ISO14443-A reader​ because it is ISO15693 compliant.
If you need an ISO14443-A compatible tag you have ST25TA64K in ST portfolio.
Best Regards,
BB
Hi Can you provide me a link to ST25TA documentation? I think the TA model does not have a I2C interface. Best Regards Gilberto Em seg, 26 de out de 2020 11:23, ST Community escreveu:
Berenice BENVEGUDA
​Hello Gilberto,
Best Regards,
BB
