2021-07-01 6:47 AM
I'm needing to get readings from more than one st25r3916 at once for a project using the pc (and java sdk). I'm unsure as to how to do this because
"STReader stReader = new STReader(); stReader.connect();"
Always connects to the same reader - the only sucess i've had so far is by running 2 instances of the program which isn't fit for purpose.
Can anybody help?
Thomas
2021-07-01 7:19 AM
Hello Thomas,
the ST25 Java SDK can manage several tags but only one reader at a given time, as you discovered.
Unless you disable the COM port of the first reader before connecting to another reader, you will always find the same device first.
Damien
2021-07-01 7:19 AM
Hello Thomas,
Damien
2025-02-11 12:55 AM
Hi all.
I have same needs of OP, using many ST25R3911B readers connected to same Windows PC host and connecting a given instance a of custom Java application to a given reader.
Are there any news about this feature with latest ST25SDK releases?
Thank you in advance.
PT
