2020-03-16 2:23 AM
I use online antenna design that provide from ST website. After i input some parameters i needed, then click and download design file. i cannot open in Altium PCB design by using import wizard. Is there any special program requires?
2020-03-17 12:11 AM
The *.prj file delivered by the eDesignSuite is not compatible with Altium.
The tool is meant to calculate the most important parameters for reader and tag antennas.
Therefore antennas have to be drawn manually in Altium.
BR Travis
2020-03-17 12:11 AM
BR Travis
