hello, I am trying to read RFID tags using the iot board b-l475e-iot01a which has a on board M24SR64 NFC , I am new to NFC and so i dont know how to build its command and am unclear how to use it, is there any example or document that might help me.
TGhau.2088
JP Miller
​Dear Customer,
Our webpage https://www.st.com/en/nfc/m24sr-series-dynamic-nfc-tags.html has a lot of information that might be of interest to you
To start with the datasheet is available in https://www.st.com/resource/en/datasheet/m24sr64-y.pdf
and contains all the commands supported by M24SR.
Software is available on the Reader side and for Android, as well as source code for the I2C Master for different targets. The link is:
 https://www.st.com/en/nfc/m24sr-series-dynamic-nfc-tags.html#tools-software
Finally application notes can be handy as well, and show examples of communication between a Reader and M24SR, or an I2C Master and M24SR.
https://www.st.com/en/nfc/m24sr-series-dynamic-nfc-tags.html#resource
I recommend in particular: AN4430 Designing an NFC Android Application for M24SR and M24LR devices
and AN4433 Storing data into the NDEF memory of M24SR
Have a good day.
JP Miller
​Dear Customer,
Have a good day.
