Hello, How can I get a detailed datasheet of ST25R3915? I can only find the datasheet of ST25R3911B,can I design a circuit based on the ST25R3915 with the direction of the datasheet of ST25R3911B? Thanks very much.
Dan--
Ulysses HERNIOSUS
Hi Dan,
for getting the DS of ST25R3915 you need to contact your local ST sales representatives.
From software perspective you can use the codes for ST25R3911B also for the ST25R3915 (except no AAT). Also the pinout is the same but electrical limits will be slightly different.
Regards, Ulysses
Ulysses HERNIOSUS
Hi Dan,
Regards, Ulysses
