2021-08-26 11:52 PM
2021-08-27 1:43 AM
can you share more details about your hardware setup:
Regarding the startup sequence, before sending the ECHO sequence, can you send a poll command and check that bit 2 is set in the poll answer?
Rgds
BT
2021-08-26 11:53 PM
I have used mikro code( https://libstock.mikroe.com/projects/view/739/rfid-click-example )as a reference
2021-08-26 11:57 PM
I am using nrf52832 with CR95HF
here are basic functions for CR95HF
void reset_cr95hr(unsigned int ch)
nrf_gpio_pin_clear(SPI_CS[ch]);
nrf_delay_ms(1);
SPI_byte_send(0x01);
nrf_gpio_pin_set(SPI_CS[ch]);
nrf_delay_ms(100);
char EchoResponse(unsigned int ch) {
int ii=5, tmp;
nrf_delay_ms(1);
SPI_byte_send(0x00); // Send cmd to CR95HF
SPI_byte_send(ECHO);
while(1){
nrf_delay_ms(1);
SPI_byte_send(0x03);
tmp = SPI_byte_receive();
if((tmp & 0x08) >> 3){
nrf_delay_ms(1);
SPI_byte_send(0x02);
if(tmp == ECHO){
return 1;
return 0;
void writeCmd(unsigned short cmd, unsigned short dataLen, unsigned int ch){
unsigned short i = 0;
nrf_delay_ms(1);
SPI_byte_send(cmd);
SPI_byte_send(dataLen);
while (dataLen == 0){
break;
for(i=0; i<dataLen; i++){
SPI_byte_send(sdata[i]);
void readCmd(unsigned int ch){
unsigned short i = 0, ii=2;
while(ii){
ii--;
nrf_delay_ms(1);
res = SPI_byte_receive();
if((res & 0x08) >> 3){
nrf_delay_ms(1);
dataNum = SPI_byte_receive();
for(i=0; i<dataNum; i++)
rdata[i] = SPI_byte_receive();
break;
nrf_delay_ms(1);
void IndexMod_Gain(unsigned int ch) {
sdata[0] = 0x09;
sdata[1] = 0x04;
sdata[2] = 0x68;
sdata[3] = 0x01;
sdata[4] = 0x01;
sdata[5] = 0x50;
writeCmd(WrReg, 6, ch);
readCmd(ch);
void AutoFDet(unsigned int ch)
sdata[0] = 0x09;
sdata[1] = 0x04;
sdata[2] = 0x0A;
sdata[3] = 0x01;
sdata[4] = 0x02;
sdata[5] = 0xA1;
writeCmd(WrReg, 6,ch);
readCmd(ch);
void Select_ISO_IEC_14443_A_Protocol(unsigned int ch) {
sdata[0] = 0x02;
sdata[1] = 0x00;
writeCmd(ProtocolSelect, 2, ch);
readCmd(ch);
// Clear read and write buffers
for(j=0; j<18; j++ ){
rdata[j] = 0;
sdata[j] = 0;
void Select_ISO_IEC_18092_Protocol(unsigned int ch) {
sdata[0] = 0x04;
sdata[1] = 0x51;
readCmd(ch);
rdata[j] = 0;
sdata[j] = 0;
void GetNFCTag(unsigned int ch) {
sdata[0] = 0x00;
sdata[1] = 0xFF;
sdata[2] = 0xFF;
sdata[3] = 0x00;
sdata[4] = 0x00;
writeCmd(SendRecv, 5, ch);
readCmd(ch);
if(res & 0x80){
for(j=0; j<dataNum; j++){
ByteToHex(rdata[j], txt_hex);
strcat(ID, txt_hex);
NFC_Flag = 1;
else {
NFC_Flag = 0;
Select_ISO_IEC_14443_A_Protocol(ch);
void ByteToHex(char input, char *output)
unsigned int ii,jj;
ii=(input>>4)&0x0f;
if(ii<10)
ii+=0x30;
else
ii+=55;
jj=input&0x0f;
if(jj<10)
jj+=0x30;
else
jj+=55;
txt_hex[0]=ii;
txt_hex[1]=jj;
txt_hex[2]=0;
void GetTagID(unsigned int ch) {
sdata[0] = 0x26;
sdata[1] = 0x07;
writeCmd(SendRecv , 2, ch);
readCmd(ch);
sdata[0] = 0x93;
sdata[1] = 0x20;
sdata[2] = 0x08;
writeCmd(SendRecv , 3, ch);
readCmd(ch);
if(res & 0x80) {
for(j=1; j<dataNum-3; j++) {
TAG_Flag = 1;
else {
TAG_Flag = 0;
void Calibration(unsigned int ch)
// Calibrate CR95HF device
sdata[0] = 0x03;
sdata[1] = 0xA1;
sdata[2] = 0x00;
sdata[3] = 0xF8;
sdata[4] = 0x01;
sdata[5] = 0x18;
sdata[6] = 0x00;
sdata[7] = 0x20;
sdata[8] = 0x60;
sdata[9] = 0x60;
sdata[10] = 0x00;
sdata[11] = 0x00;
sdata[12] = 0x3F;
sdata[13] = 0x01;
writeCmd(Idle, 0x0E,ch);
readCmd(ch);
sdata[0] = 0x03;
sdata[1] = 0xA1;
sdata[2] = 0x00;
sdata[3] = 0xF8;
sdata[4] = 0x01;
sdata[5] = 0x18;
sdata[6] = 0x00;
sdata[7] = 0x20;
sdata[8] = 0x60;
sdata[9] = 0x60;
sdata[10] = 0x00;
sdata[11] = 0xFC;
sdata[12] = 0x3F;
sdata[13] = 0x01;
readCmd(ch);
sdata[0] = 0x03;
sdata[1] = 0xA1;
sdata[2] = 0x00;
sdata[3] = 0xF8;
sdata[4] = 0x01;
sdata[5] = 0x18;
sdata[6] = 0x00;
sdata[7] = 0x20;
sdata[8] = 0x60;
sdata[9] = 0x60;
sdata[10] = 0x00;
sdata[11] = 0x7C;
sdata[12] = 0x3F;
sdata[13] = 0x01;
readCmd(ch);
sdata[0] = 0x03;
sdata[1] = 0xA1;
sdata[2] = 0x00;
sdata[3] = 0xF8;
sdata[4] = 0x01;
sdata[5] = 0x18;
sdata[6] = 0x00;
sdata[7] = 0x20;
sdata[8] = 0x60;
sdata[9] = 0x60;
sdata[10] = 0x00;
sdata[11] = 0x3C;
sdata[12] = 0x3F;
sdata[13] = 0x01;
readCmd(ch);
sdata[0] = 0x03;
sdata[1] = 0xA1;
sdata[2] = 0x00;
sdata[3] = 0xF8;
sdata[4] = 0x01;
sdata[5] = 0x18;
sdata[6] = 0x00;
sdata[7] = 0x20;
sdata[8] = 0x60;
sdata[9] = 0x60;
sdata[10] = 0x00;
sdata[11] = 0x5C;
sdata[12] = 0x3F;
sdata[13] = 0x01;
readCmd(ch);
sdata[0] = 0x03;
sdata[1] = 0xA1;
sdata[2] = 0x00;
sdata[3] = 0xF8;
sdata[4] = 0x01;
sdata[5] = 0x18;
sdata[6] = 0x00;
sdata[7] = 0x20;
sdata[8] = 0x60;
sdata[9] = 0x60;
sdata[10] = 0x00;
sdata[11] = 0x6C;
sdata[12] = 0x3F;
sdata[13] = 0x01;
readCmd(ch);
sdata[0] = 0x03;
sdata[1] = 0xA1;
sdata[2] = 0x00;
sdata[3] = 0xF8;
sdata[4] = 0x01;
sdata[5] = 0x18;
sdata[6] = 0x00;
sdata[7] = 0x20;
sdata[8] = 0x60;
sdata[9] = 0x60;
sdata[10] = 0x00;
sdata[11] = 0x74;
sdata[12] = 0x3F;
sdata[13] = 0x01;
readCmd(ch);
sdata[0] = 0x03;
sdata[1] = 0xA1;
sdata[2] = 0x00;
sdata[3] = 0xF8;
sdata[4] = 0x01;
sdata[5] = 0x18;
sdata[6] = 0x00;
sdata[7] = 0x20;
sdata[8] = 0x60;
sdata[9] = 0x60;
sdata[10] = 0x00;
sdata[11] = 0x70;
sdata[12] = 0x3F;
sdata[13] = 0x01;
readCmd(ch);
2021-08-26 11:58 PM
int main(void)
nrf_gpio_cfg_output(SPI_CS[0]);
nrf_gpio_cfg_output(SPI_CS[1]);
nrf_gpio_cfg_output(SPI_CS[2]);
nrf_gpio_cfg_output(SPI_CS[3]);
nrf_gpio_cfg_output(SPI_CS[4]);
nrf_gpio_cfg_output(SPI_CS[5]);
nrf_gpio_cfg_output(SPI_CS[6]);
nrf_gpio_cfg_output(SPI_CS[7]);
nrf_gpio_cfg_output(SPI_CS[8]);
nrf_gpio_cfg_output(SPI_CS[9]);
SPI_init();
nrf_gpio_pin_set(SPI_CS[0]);
nrf_gpio_pin_set(SPI_CS[1]);
nrf_gpio_pin_set(SPI_CS[2]);
nrf_gpio_pin_set(SPI_CS[3]);
nrf_gpio_pin_set(SPI_CS[4]);
nrf_gpio_pin_set(SPI_CS[5]);
nrf_gpio_pin_set(SPI_CS[6]);
nrf_gpio_pin_set(SPI_CS[7]);
nrf_gpio_pin_set(SPI_CS[8]);
nrf_gpio_pin_set(SPI_CS[9]);
nrf_delay_ms(100);
reset_cr95hr(0);
nrf_delay_ms(3);
while (!EchoResponse(0));
nrf_delay_ms(3);
//Calibration(0);
//nrf_delay_ms(3);
IndexMod_Gain(0);
nrf_delay_ms(3);
AutoFDet(0);
nrf_delay_ms(3);
Select_ISO_IEC_14443_A_Protocol(0);
nrf_delay_ms(3);
//Clear_Screen(0);
//string_display("ERR1", 2, 0);
while(1){
if (!TAG_Flag)
GetNFCTag(0); // Get NFC ID
if (!NFC_Flag)
GetTagID(0); // Get Tag ID
if (ID[0] == 0){ // If there is no tag present
flag++; // Increment counter flag
else { // If tag is present
flag = 0; // Reset counter flag
{ // Compare previous and current tag ID
//UART1_Write_Text("Tag ID:");
//UART1_Write_Text(ID);
//UART1_Write_Text("\r\n");
ble_send("OK\r\n", strlen("OK\r\n"));
strcpy(ID_old, ID); // Set current ID as previous ID
nrf_delay_ms(100);
if(flag > 2){ // If counter flag has reached value > 5
//UART1_Write_Text("Put the Tag over the Antenna\r\n");
ble_send("NOT\r\n", strlen("NOT\r\n"));
ID_old[0]= 0; // Terminate the old ID string
ID[0]= 0; // Terminate the ID string
for(j=0; j<18; j++){
rdata[j] = 0;
sdata[j] = 0;
2021-08-27 1:43 AM
Rgds
BT
