control reader command
mossaab daiki
Posted on June 29, 2018 at 12:55
Hello, Can I configure ST25 reader to send only 13.56 MHz carrier ? if So how to do that?
Ulysses HERNIOSUS
Posted on July 10, 2018 at 14:28
please have a look into the DS (
https://www.st.com/resource/en/datasheet/st25r3911b.pdf
 :( Search for 'en' 'I_osc', etc.
Transparent mode has 0xdc, no 16 bits!
Regards, Ulysses
5 REPLIES 5
Ulysses HERNIOSUS
Posted on July 03, 2018 at 08:21
Hi Mossaab,
You just need to enable the Oscillator (en bit in register op control), wait for I_osc, and then set tx_en => constant wave.
Regards, Ulysses
Posted on July 03, 2018 at 09:40
Hi Ulysses,
thanks for the reply do you recommend a specifi ST25 reader ?
regards
Mossaab
Posted on July 09, 2018 at 10:24
Hi Mossaab,
to date there is only one chip available on the boards in the web shop: ST25R3911B. You can either get it as ST25R311B-DISCO with a PC software or as a nucleo shield: X-NUCLEO_NFC05A1.
ST25R3912 .. ST25R3915 are compatible variants.
For your own developments the nucleo shield might be more suited.
Regards, Ulysses
Posted on July 10, 2018 at 10:05
Thanks Ulysses
I have now the TR25R3911B-Disco. folowing your previous response couled you please guide me more for this steps:
  • what's the the en bit number of the oscillator?
  • where can i find I OSC as your recommend?
  • if there are any document can help to set what i need could you please  tell where i can find it?
  • Actually I did find that transparent mode has 00CD ID is it correct?
many thanks
mossaab
Ulysses HERNIOSUS
Regards, Ulysses
