2015-11-13 2:20 AM
Hello
Does someone know if it's possible to use the CR95HF in a reverse mode to emulate a badge instead of being a reader ? Best RegardsSolved! Go to Solution.
2015-11-13 2:37 AM
CR95HF can operate only as Reader/Writer. For card emulation you will have to use RX95HF which can operate only as card, or ST95HF which supports Reader/Writer, Card emulation and Peer to Peer.RegardsPetr2015-11-13 2:37 AM
CR95HF can operate only as Reader/Writer. For card emulation you will have to use RX95HF which can operate only as card, or ST95HF which supports Reader/Writer, Card emulation and Peer to Peer.RegardsPetrWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
