what is the suitable buck converter that could convert 55volts to 5volts 10amps
Aanil.1
i need a dc-dc step down power supply where the input varies from 45-55volts and required output of 5volts and 10amps
Patrizia BELLITTO
you can use eDesignSuite to easily select and design your power supply converter.
Insert your specifications and the suitable ICs will be shown.
Best regards,
Patrizia
