we are using Viper16LN to generate 12VDC and 5VDC from 230 VAC. 2 bulky capacitors 10uF 450V are used in i/p side of Viper as per AN2872 Application note. These high value capacitors height is more but we have height constraint max 10mm.
eedes.1
so any solution..
