The Serial communication of the IPFC01C1 does not work. Does anyone know a solution for this issue?
JBeye.1
Hello!
I purchased this week the STEVAL-IPFC01V1 development board. When I connect AC and then I switch the load on: the circuit works.
But now I want to change some settings from the IPFC01C1 controller:
I used a FTDI chip (FT232) to try to communicate to the controller. When I open the STNRGPF0_Firmware_Loader tool, I can select the COM port of the chip (COM4). But when I try to "Read FW", I see the TX LED of my serial converter blinking a few times and the clock of the mouse pointer stays at the screen and nothing happens.
What can be a solution for this issue?
kind of regards,
Jens
0 REPLIES 0
