2025-10-08 1:43 AM
Hi Sir,
I'm looking for the data sheet and programming guide for the STWLC38JRM to develop the off-line programming algorithm. Would you please share such information for reference. Thank you.
2025-10-30 2:23 AM
Dear Rickey_Chien,
Please contact your local distributor so that they will be able to guide you depending on your project. Indeed, the support for mass market has been restricted, which explains why the documentation has been retrieved from the website.
If you have already started your project based on STWLC38, you can also open a case on st.com (https://www.st.com/content/st_com/en/support/support-home.html#), you ticket should be re-directed to the support team.
2025-10-30 2:23 AM
Dear Rickey_Chien,
