SP1050
Mohamed GHOZLANI
We are using the SPV1050 charger for our device, and we are planning to certify our device with FCC standards, so can you please advise some recommendations on the PCB design to fit the FCC requirements?
Also, someone recommend me to use a series resistor on the input power to reduce the radiation generated by the inductor, does this make sense?
Thanks!
0 REPLIES 0
