Reverse Polarity with ST1S14
2025-02-07 4:04 AM - last edited on 2025-02-07 4:16 AM by Peter BENSCH
Hello I have created reverse polarity but it can not work stable especially in the first work , this time I change the voltage a little bit it works :) ı cant understand.
What should ı do?
- Labels:
DC-DC Conversion
2025-02-07 6:01 AM
Welcome @EN11, to the community!
- What output current do you want to draw at -15V_O?
- What is the saturation current of L2?
- Can you please show the layout so that this can be checked?
/Peter
2025-02-07 6:19 AM
I am using the just supply for opamps , and also ı guess understand problem is a lot capacitors ı put the resistor in the output problem seems to be solved.
but ı continue to try .
Best Regards.
