in-rush current control
btremaine
Posted on June 03, 2014 at 01:40
I am working on a large system that is comprised of several different subsystems supplied with AC mains. In order to control inrush current to the system I want to build a controller that switches on AC duplex outlets at delayed times and the input mains should have in-rush current control.
  My two questions are:
    1. Not wanting to use relays, is an SSR a good approach to controlling AC mains in to AC out?
    2. For inrush current control NTC's are ineffective. Could I use a pi filter network to do this? Or is a zero-crossing turnon SSR a better approach, or something else?
Thanks,
0 REPLIES 0
