2020-12-18 12:47 PM
From looking at the datasheet for ST1PS02BQTR, I was able to determine what the default current limit, and that I just need to place a resistor there to set the current limit, but I didn't see any other documentation about what the relationship between the resistor value and the current limit.
2020-12-21 5:56 AM
Please do not get confused by the words "current limit". Here it means the current limit of the high-side MOSFET switch. Its corresponding values are given in table 6, block Power switch for a resistor of:
Please remember the function of a synchronous buck converter: it is the peak inductor current, not the DC output current.
Good luck!
/Peter
