How can I enable spv1050 ldo's
I have an eval board steval-isv019v1. It is for boost config of spv1050. I connected pv yo pv input connector, a li-po battery to battery output and a 22kohm load to ldo output. I measure pv input voltage as 1.5 volts, store voltage as 3.92 volts and ldo_en pin voltage as about same as store voltage. But ldo outputs are 0 volts. How can I enable ldo's. Do I need any thing else? Whats wrong with my eval board?
