2024-11-21 7:48 AM - last edited on 2025-01-02 5:11 AM by Peter BENSCH
Could anyone help me to identify attached smd diode?
2024-11-21 7:58 AM
Welcome @sevco, to the community!
The marking EBQ stands for the SMAJ130CA-TR.
Hope that helps?
/Peter
2024-11-21 7:58 AM
Hope that helps?
/Peter
2024-11-21 8:27 AM
Thank you Peter, did you check the attached photo?
Regards Sascha
2024-11-21 9:27 AM
Yes, your attached photo shows an SMA package with three lines:
The 1st line contains the logo plus some eco markings, the 2nd line the relevant marking and the 3rd line the date code.
2024-11-21 11:09 PM
Thank you very much Peter.
Best regards sascha
