FAQ_STC3117
Gregory Go.
Senior II
  • 1. What is the different between STC3115 and STC3117?
STC3117 is an improved version of STC3115.
See the differences between both parts in the attached document. (STC3117_vs_STC3115_comparison.pdf)
  • 2. How often is measured the temperature?
STC3117 measures first the temperature during power-up (after 725ms).
Then STC3117 measures the temperature 2.5s after enabling GG_RUN
Then the temperature is measured periodically each 16s (as long as GG_RUN is enabled)
See the attached document: STC3117_measurements_cycle-Timing_Diagram.pdf
0 REPLIES 0
