digital light dimmer
l90mehdi
Posted on October 08, 2016 at 16:08
hi every one
i am working on the digital light dimmer. i control my ssr by stm32f1.
i have big problem.i want design the circuit that protect ssr(triac) when load will be short so that ssr not damage.
but  any method that i know can not  hep me.
this topic should be in other group such as power electronic
but if any body know the my question please help me.
Benoit RENARD
Posted on December 01, 2016 at 11:50
Hello Medhi,
Triac is a device that is automatically turned off at the zero current when not drived by a gate current. No way to turn the device off when the current is flowing.
Even if the Triac technology allows high current robustness compare to MOSFET technology, if a short-circuit of the load appears when the Triac is ON, the way to protect the Triac is to add a fuse in series with the Triac and the load.
To design the fuse and to be sure that the Triac can withstand safely the high current before the cut-off event, take a fuse with a I²t parameter below the Triac specified I²t (see datasheet of your Triac).
Hope it helps,
Best Regards
Benoit
Benoit RENARD
Hello Medhi,
Hope it helps,
Best Regards
Benoit
Tinh Nguyen
Posted on June 16, 2017 at 06:57
Hi
Medhi,
Do you know about Triac T1635-700G-TR. I'm doing about this IC.
Posted on June 20, 2017 at 15:05
Hi Dear Tinh.
No I am working on power MOSFET
because short circuit protection is impossible with triac.
I'm sorry that I can not help.
thank you
