Can we use 760308101216 (6mm dia) RX coil with STEVAL-ISB68WA EVK board to check the functionality of the STWLC68 receiver IC
SJyot.1
Can we use 760308101216 (6mm dia) RX coil with STEVAL-ISB68WA EVK board to check the functionality of the STWLC68 receiver IC.
Application is Medical (Unit will place under the denture). Due to space constraint we are planning to use small size RX coil, please confirm it will work for 1 to 1.5W power requirement.
After proven the wireless charging method in EVK , we will consider the same circuit & coil in our custom design.
SJyot.1
Please provide your comments on above queries. Distance between TX coil and RX coil is 2mm max. and required power is 1W max.
Can we physically swap the coil (6mm dia) in EVK board for the evaluation or any modifications required. Please confirm with your comments.
It is an urgent requirement.
SJyot.1
Can you provide your comments please.
SJyot.1
Can you provide your reply on my query.
