SS.15
电池管�?�芯片STC3100
  • April 22, 2021
  • 790 views
STC3100外部32.768K是MCU�??供还是晶振�??供?
    Winfred LU
    In case of using an external clock source, usually it is provided by a MCU/RTC for the 32,768 Hz signal.
    The internal oscillator can be inhibited to force the use of an external signal by setting the SEL_EXT_CLK bit in the REG_MODE register.
    SS.15
    SS.15Author
    �?用MCU产生,�?�以直接接外部32768Hz有�?晶振�?�。
