How can I get code back from stm32 using atollic studio?
AF.1
Hello I recently format my computer and I lost project that is saved on my stm32. Can I somehow get this code back if the code is inside?
MM..1
Chief III
When you no lock device, you can download back hex or binary flash image. Use stlink utility. But for your source code you can say bye bye
You can pull the binary/hex file out using STM32 Cube Programmer
Source code will be lost, the object code can perhaps be disassembled.
