Board not reacting to simulink build STM32F407G_DISC1
skeeiff
I am trying to establish contact with the board via simulink by blinking an LED. I followed this tutorial. The code built but there is no reaction from the board. I get the following errors from Simulink but it says target built successfully.
Any help would be appreciated - I'm sure it is a simple fix I just do not know what to do.
Andrew Neil
Simulink is a MathWorks product - nothing to do with ST - so you need to go to MathWorks for help:
https://uk.mathworks.com/help/?s_tid=nav_help_doc
This part looks like the flash programming is failing - "verification" refers to reading-back the Flash content to confirm that it matches what should have been programmed.
