Others: STM32 MCUs related
Find out more about STM32 implementations with external components, discuss use cases, and discover how to use new tools and ST components.
STM32F03 I2C1 not working?
i want to store data in to I2C EEPROM AT24C02 so in MCU I2C1 is used but i saw in oscilloscope I2C1 both pins are remains lowI2C2 works fine with i2c LCD.i placed pull up resistor 10k both line CLK & SDA in EEPROM.EEPROM address 0xA0how to solve it?e...
Acces and modify a constant in flash memory
I have the following trouble:​I am using a radio which needs a address and channel parameters, this is given in production phase. So I am planning to flash every board with this parameters modified each time before the board is flashed.​This paramete...
JCuna.1 by Senior
  • 6011 Views
  • 14 replies
