What does ''LD eval1+1,A'' do?
kane
Posted on February 09, 2004 at 10:10
What does ''LD {eval1+1},A'' do?
kane
Posted on February 09, 2004 at 07:33
I'm trawling through some ASM code I need to update (not written by me) and having trouble interpretting some of it...
LD {eval1+1},A
Load acumulator to eval1... what does the +1 bit do? Is this to address the MSB, LSB?
sjo
Posted on February 09, 2004 at 08:46
For instance if you define a word in memory, eg. eval DS.W 1
LD {eval1+1},A would write to the low byte
LD {eval1},A would write to the high byte.
This is if MOTOROLA (Big endian) has been defined, if using INTEL (little endian) then the opposite applys.
sjo
kane
Thanks, thats excellent
