Warning message
ongth60
Posted on April 08, 2005 at 04:49
Warning message
ongth60
Posted on April 06, 2005 at 08:52
Hi all,
Can you help me figure out the problem below?
''scat.scf'', line 19: Warning: L6314W: scat.scf(line 19, col 13) No section matches pattern *(RW).
Finished: 0 information, 1 warning and 0 error messages.
i've copied the required files from templates, lib_Linked folder and also the main.c from the examples folder. Pls advice. Im trying to run this progrm on the STR710-EVAL.
sjo
Posted on April 06, 2005 at 09:27
You can ignore this warning, it is just informing you you have unused sections and it is removing them form the link stage.
sjo
ongth60
thanks for d fast reply.
