Viper 26LD loosing regulation
- July 2, 2016
- 11 replies
- 3115 views
Posted on July 02, 2016 at 12:44
I have used eDesign to implement viper on my application. My specs are input voltage 70Vdc to 160Vdc / output 15Vdc (5.1W). For some reason, the viper 26LD is loosing regulation (when connecting to a load) - the output voltage decreases as the load increases. Furthermore, I heard buzz coming out of it. After replacing the component a few times, the buzz stopped but I still didn't get the right output voltage.You may find attached the schematics!Thanks in advance for your support. #retification #viper-26ld
