USB Library : how to make ControlOut with data ?
shangdawei1
Posted on June 27, 2007 at 02:57
shangdawei1
Posted on March 26, 2007 at 04:36
for ControlOut with data, i think it is follow:
Setup Data0 Ack
Out Data1 ack
Out Data1/0 ack
In Data1 ack
void My_Status_In (void)
//process recived data <===== the code can not be executed
but for ControlOut without data, it can be executed.
where is error ? I use STR710 and IAR.
[ This message was edited by: shangdawei on 26-03-2007 08:08 ]
shangdawei1
usb_core.c
* Function Name : Out0_Process
* Description : Process the OUT token on all default endpoint
* Input :
* Output :
* Return :
u8 Out0_Process(void)
u32 ControlState = pInformation->ControlState;
if(ControlState == OUT_DATA || ControlState == LAST_OUT_DATA)
DataStageOut();
ControlState = pInformation->ControlState; /* may be changed outside the function */ /* Add for Control Out with Data */
else if (ControlState == WAIT_STATUS_OUT) {
(*pProperty->Process_Status_OUT)();
ControlState = STALLED;
else if (ControlState == IN_DATA || ControlState == LAST_IN_DATA) {
/* host aborts the transfer before finish */
/* Unexpect state, STALL the endpoint */
else {
pInformation->ControlState = ControlState;
return Post0_Process();
} /* Out0_Process */
