UART0 Bug in 91x_uart.c
rgreenthal
Posted on March 05, 2008 at 19:24
rgreenthal
Posted on May 17, 2011 at 11:32
Another Bug-- This time in your NEW FWLib for the UART
Where is UART0? see your own comments
Too many bugs in NEW release
* Function Name : UART_DeInit
* Description : Deinitializes the UARTx peripheral registers
* to their default reset values.
* Input : UARTx: where x can be 0,1 or 2 to select the UART peripheral.
* Output : None
* Return : None
void UART_DeInit(UART_TypeDef* UARTx)
/* Reset the UARTx registers values */
if(UARTx == UART1)
SCU_APBPeriphReset(__UART1,ENABLE);
SCU_APBPeriphReset(__UART1,DISABLE);
else if(UARTx == UART2)
SCU_APBPeriphReset(__UART2,ENABLE);
SCU_APBPeriphReset(__UART2,DISABLE);
