UART & USB Run Together
sg
Posted on December 28, 2005 at 03:06
sg
Posted on May 17, 2011 at 12:09
I am new Firmware programmer. I gone through the UPSD3234A's Datasheet, it said the USB must run on 12, 24, 36MHz for MCU. I was wonder how am i able to have UART0, and USB together on a single design and run. because with 12, 24, 36MHz, i cannot get my desired baudrate, eg, 9600, 19200.
Please Advise.
wek2
Using Timer2 as baudrate generator, 9600Baud is possible with 12MHz crystal with negligible (0.16%) error; similarly 19200Baud with 24MHz crystal.
A good tool for baudrate calculation is at the Keil pages:
http://www.keil.com/c51/baudrate.asp
Jan Waclawek
sg
THANKS A LOT. I TRIED ON IT, IT DOES HAVE SOME SMALL PERCENTAGE OF FAULTY ON 9600 BAUDRATE. ANYWAY, I GUESS I STILL STICK ON UART DESIGN.
tHANKS.
