To using slave mode (I2C)
vcorea
Posted on November 20, 2003 at 01:26
vcorea
Posted on May 17, 2011 at 11:56
I'm using two uPSD. One of them is master and the other is slave .
I use Keil C. There are no problem to work except one.
That is to declare a data type in slave .
If I declare a variables for using S2DAT in idata, It is no problem.
But I do in xdata, it does'n work.
for example
unsigned char xdata buff[10]; does'n work;
unsigned char idata buff[10] ; OK
There is no problem like that in master just slave .
How can I fix it.
mailto:null
