Str9 comStick USB/JTAG Problem
wolfgang239955
Posted on January 17, 2008 at 00:05
5 REPLIES 5
wolfgang239955
Posted on May 17, 2011 at 09:46
hi everyone,
we bought the str9 comstick and tried some examples, without any problem. but now, when i want to programm the stick, a flasherror will occured.
i am using:
- hitop (5.20.322) for str9-comstick
- arm-hitex-elf-gcc-4.0.3
- str9 comStick
i've done:
- reinstall all drivers (comstick was detect by windows xp)
- reinstall hitop
- tried different usb connectors/ports
the errormessage:
FlashCW_10
An error detected while flash programming: the flash algorithm did not run properly in target. this could happen due to the following reasons:
-the specified RAM space is not accessible.
-wrong JTAG settings.Load Target Code
so, i hope somebody could help me and sorry for my terrible english.
hapyang204
Hello ,everyone.
I am a novice in flash use.
I plan to use a 2M flash to store my data , then FPGA read the data written in the flash. The problem is what tools and software i need to use? How about using jtag to download the data sheet.How could I write the data into the flash?
Can someone help me? Thanks very much.
dariovecchio
Hi linus_van_pelt,
I had exactly the same problem and I solved it.
For some reason flash sectors are protected.
You can unprotect them using OpenOCD (I compiled latest svn version using cygwin under WinXp).
If you need specific help let me know.
lazycat1049
Dear dariovecchio,
I also encountered this problem recently. May i know how to solve it using Open OCD or other methods?
Best Regards,
lazycat
jalil
Was there ever a reply from dariovecchio regarding this problem? How did you solve it?
