Starttup code and global variables
marcus23
Posted on January 06, 2005 at 09:39
marcus23
Posted on January 05, 2005 at 11:34
got a problem with initialization of global variables. If I try to assign a value to a global variable like this:
int MyInt[]={1,2,3,4};
it won´t work safely (sometimes it works, sometimes it won´t). So, is there another startup file that is needed to initialize these variables while declaring them? I know we had a similiar problem with a compile for ST7 some time ago, and there another startup while was needed to change this behaviour.
Best Regards,
Marcus
marcus23
Posted on January 05, 2005 at 11:35
I forgot:
I´m using RVDK1.0 and RVDS 2.1
marcus23
Thank you RISC, that was the hint I was searching for :)
