ST6 hex file disassembly
gldame
Posted on February 22, 2006 at 14:23
5 REPLIES 5
gldame
Posted on September 16, 2005 at 23:50
I am trying to reverse engineer an existing ST6 application. I have the .hex file but no source files. Are there any free or cheap tools that can decode the .hex file and generate the assembly instructions?
sjo
Posted on September 19, 2005 at 06:43
I wrote a plugin for IDA (http://www.datarescue.com), it is available at
http://groups.yahoo.com/group/idaextensions/files/Modules
other solutions include using the ceibo kit. its been a while since i have ventured down the st6 route.
sjo
gldame
Posted on September 21, 2005 at 18:13
I took a quick look at the plug in files that you refered me to, but I don't know how to use a plugin. Does IDA Pro have a simple mechanism for activating and using the a group of files such as these?
Thanks for your help in advance.
Gary
sjo
Posted on September 22, 2005 at 08:40
Just place the plugin in the ida directory and it will be found.
sjo
curuchupa
Hi there
I was reading this forum and I found this issue, and I am now in the same problem.
Could you tell me, how about decompiling the hex file, and if was successful.
I’m trying to do the same thing but I have problems.
please send message to
mailto:curuchupa@hotmail.com
Quote:
