ST10 external RAM interface
mhodkin9
Posted on May 23, 2003 at 19:04
mhodkin9
Posted on April 30, 2003 at 03:20
The ST10 when configured for an external 16 bit data bus can write 8 or 16 bits of data by using the WRL- and WRH- signals.
What it appears to be impossible to do is to connect the ST10 directly to any of the standard 16 bit RAM chips that use the BHE- and BLE- signals (Cypress, Renesas etc) - without using glue logic which will slow down the interface.
This seems difficult to accept so maybe I have missed the obvious.
Can anyone advise.
Thanks,
Mike
mailto:m.hodkin@hamjet.co.nz
maxime2399
Could you please give some memory part numbers example, it would be easier for me to verify?
